Have some of you experienced difficulty in making calls ??
Kal H.
Kal H. Posts: 49 ✭✭
I have noticed a strange issue where sometimes you dial a number to call, and you place that call, and all that sudden it drops the call.
Calling it a second time usually works. Figured I would share it here though and see what you all have to say!
  • Code_KRUEW
    Code_KRUEW Posts: 400 ✭✭
    Yes, I've had the same experience in the last week or so.
  • Peenis
    Peenis Posts: 91 ✭✭
    People have difficulty trying to call me. It doesn’t ring and on their end it says that there’s been a error wtf
  • Francesco V.
    Francesco V. Posts: 16 ✭✭
    After going into contacts certain calls will just not connect even though the message shows "calling" usually hanging up and redialing will solve the issue.
