Oneplus says: ''Even if a device supports some or all of the required frequencies for this carrier, it will not be able to connect unless the device is approved for this network.''
Just making sure, thx!
Sounds to me like this statement may be referring to a phone that may be "locked" to a specific network. As long as a phone is unlocked, which all new phones are now, it should work if it supports the required frequencies for Fizz.
You can check if your phone is compatible with Fizz network on the following link :
https://willmyphonework.net/
Have a nice day.
The one plus phones are unlocked, and they support all the required frequencies
Till now I do not have problems in Canada and US with Fizz and OP5T
That maybe the same problem that Fizz actually have with some Huawei models. (https://mobilesyrup.com/2019/04/12/huawei-devices-fizz-mo...)
Yes, it should. I have tested the Sim in a Oneplus 3t, Oneplus 5t, and currently, a Oneplus 6. They all work fine.
If this answers your question, please select the best answer right below, thank you. Have an excellent day:)
@Mike, yes I know the OnePlus phones are unlocked. I was just trying to make heads or tails of that statement that was given.
