Can I activate a new sim card in my previous account? I dropped my phone in the water and I need a new sim card as well. How do I do it?
Yes, you can. But not active the sim, use change SIM card. If you activate, you will create a new plan.
Are you sure the SIM is bad? Let it dry and try it on another phone first.
Yes you can replace the sim cart, but check it before
Have you tried putting your phone in a ziplock bag full of uncooked rice?
Do some research. Your phone may still work, but take precautions like removing the battery first.
Even if the phone is gone, the Sim may still work if you apply some rubbing alcohol to the contacts and dry it before trying to use. As others have said, the SIM can be replaced.
Thank you, everybody! I already did all the suggestions above and took my phone to a specialist and there is no way to fix it. As per the Sim card, I don't have it with me anymore :(
