nothing work , my lte dosent get any signal so its usless and half of my text dosent reach...or i dont get text when people speak to me...
Hey El Capitaine ;)
I would start with the following suggestions from -
@Lopressor, @Mikle and @MT. If that doesn't work, please contact us :)
Jay
Contact fizz support. They will open a ticket and fix it for you.
Hang on there !
Check your APN settings and make sure your phone is compatible with Fizz's frequency. Make sure your phone is unlocked (obviously) and try inserting another sim card in your phone.
If nothing works, on your plan, click on unsubscribe button and you should see a chat bubble right away to contact Fizz.
Good luck
Which phone are you using (can you give the exact model), for example there exists two iphone 8 (A1905 et A1907) this can apply to almost all the phones since this can impact your LTE problem.
Verify if your phone is compatible with FIzz regarding data https://fizz.ca/en/faq/compatible-devices
You can get a refund during trial period https://fizz.ca/en/faq/unsubscribe
