Hi Mark
When you have Canada & USA coverage, it means you can use your phone in both Canada and USA. If you have any questions about a specific town or area, you can check...
Anyone have roaming experience in Vermont, New Hampshire, Maine and Massachusetts in the USA?
I will be travelling 4-6 days per month to above states for business trips...
Hello Roberto
Sounds like Fizz mobile will be a perfect fit for your needs.
Make sure to take Canada + USA coverage when you sign up.
I have used Fizz in USA and...
A little background:
I have Full Unlimited US and Canadian Coverage.
Mobile Data works fine and is always on.
Making and receiving calls works all the time.
I cannot...
Hello James
First we should rule out whether the sender is having any problems.
Is it happening with a specific US sender or multiple?
Can you confirm whether the US...
Hi there I am in the USA and after 2 days my data are not working working. I have 8 GB of data available on my plan. I can receive calls and make calls, but the data icon is not...
Hi Philippe,
here we are users like you we can only give you suggestions
Double-check the data roaming? After your reset probably it was not configured.
Can you try...
Hi Karen
This is the rule
"We reserve the right to interrupt or block access to our network of partner providers Fizz EXT if you use your mobile service primarily on...
