What web site you recommend to test the internet speed.
Speedtest.net net is the best option make sure you use the correct server. if not you may not get the real speed.
https://testvitesse.videotron.ca/index-en.html
Videotron speed test works pretty good as well. In any case, don't use the one Google has.
Videotron speed test give a speed of 20 instead of 120
Fast.com (by Netflix) is also a good alternative.
If those suggestions don't work most major internet providers provide their own speedtest. I've used Bell, Telus and Rogers all in the past.
You can download the app and it will give you a very good test, or you can try
https://www.speedtest.net
https://www.fast.com
Just type "speed test" into google and you will see a blue button that says "RUN SPEED TEST". Just click it and Google will tell you your download and upload speeds.
In order to get the best results, you will need to be hardwired to the modem and run the test with no other devices connected(disable the wifi on the modem).
Close all running programs and run the speed test from your preferred browser.
Most accurate web site is speedtest.net, powered by Oookla, but make sure you select a test server that has lots of ressources (Bell, Telus, Rogers, Techsavy, FibreNoir, ect..).
Hope it helps!
Use fast.com, very straight forward and easy to use.
Shilgi was made best respondent
MT was made best respondent
kevin answered
Philippe was made best respondent
ThomasK answered
Philippe answered
Adriana answered
Kevin answered
DavidP answered
Takion answered
Andrei answered
Shilgi answered
MT answered
Takion posted a new question
