I'm in Ottawa where LTE is working fine. I just travelled to Cornwall and had zero data signal. I used to live there and had 100% coverage with another provider so I know the...
I did a check with my phone and you are totally right....I cant connect to fizz.ext LTE.
I was able to switch and the voice is working. But no data not even HSPA or 3G...
Hi Estefano
With Fizz (and Videotron), their LTE band is AWS or Band IV (which is 1700/2100 MHz). It doesn't penetrate buildings as well as, for example, 700 MHz LTE, which...
The Fizz map coverage is really simple and with no details like 3G,HSPA,LTE,LTE+......
Can we use Videotron coverage map also for Fizz ?
Has FIZZ access to all Videotron...
Hello Éloïse,
Apologies for the unpleasant situation.
Have you verified if your phone's APN ( Android) is configured as shown on the FAQ Lieux has provided? If your phone...
I’ve come back from Calgary to Montreal where I live and I haven’t been able to get lte for at least a month and I used to always be on LTE. I’ve rebooted my phone so many times...
Hi Sabarina,
Are you able to try your Fizz SIM card on another phone? Just to see if LTE works with another phone. If yes, then there may be an issue or incorrect setting...
