how do i add Canada USA to my plan? i have now a Quebec plan
You can change your coverage by going to <my plans>, click on <Manage Plan>, click on <Ajust Plan>, Click on <Change Plan> and change your coverage to Canada Usa
Also you can buy add on by going to <My plans>, <Manage Plan>, < Add on> , click on International Call and enter either Canada or United States. ( they're in the same zone 1 )
Everything M T. wrote and
When adjusting your plan, it will only take effect on your next billing cycle. For the current cycle, you would need to get an add-on.
Don't forget the plan changes will only be active on the next billing cycle. If you need it right away, get an add-on as M t. mentioned.
One more thing to add: Adjusting your plan will only take effect on your next billing cycle. For the current cycle, you would need to get an add-on.
It's also probably best to change your plan sooner rather than later once the intro prices are gone it won't be possible to add options for cheap.
MT was made best respondent
Code_KRUEW answered
Ken answered
Francis answered
Code_KRUEW answered
MT answered
MT answered
gershon posted a new question
