Any help how to receive SMS from Uber and Lyft in Ottawa area?
I could not receive SMS from UBER and LYFT any one has any solution How can be solved this problem?
Yousuf
Yousuf
Yousuf
Level
This is a known and ongoing issue that has to do with short code sms. It has been like that for months and I don’t believe we have an estimated time for when it’ll be fixed. You can learn more here: https://community.fizz.ca/questions/1808946-sms-2-factor-authentication-issues
Did you find this useful ?
No (0)
Yes (0)
Chris
Chris
Chris
Level
3
2249 / 5000
Hi Yousuf,
As mentioned above, this is a big issue that is being worked on for the past months. Hopefully it will be fixed soon, for the meantime, I recommend using a third party calling and texting app.
Cheers
Chris P.
ThomasK
ThomasK
ThomasK
Level
5000 / 5000
Fizz is still working on it.
