How to tranfer my calland text toward another line
You can only do call forwarding here are all the codes for Fizz (does not work for text msg)
https://fizz.ca/en/faq/how-do-i-set-up-call-forwarding
Chizz :))
You cant do that, there is no way to forward texts
You can do this simply on your current phone by going to the dialpad, enter *72 followed by your desired number, for example if you want to forward to 613-282-xxxx just type *72613282xxxx on the dial pad.
Cheers
Chris P.
Only call working, no text forwarding.
