Is roaming restriction of Fizz same as Videotron?
Is roaming restriction of Fizz same as Videotron? I may stay in Toronto for more than 6 months and will stay in Rogers covered area and 99% use rogers towers. Will I be blocked because of roaming 6 months? I was with Rogers before so I know it's always Rogers signal for the place I stayed.
1
Hello Tom,
Regarding your question, the expanded coverage zone is intended for occasional coverage and if you use your mobile service for 3 consecutive payment periods we reserve the right to interrupt or block access to our network of partner providers.
You can find more info about this on our faq link: "https://fizz.ca/en/faq/partner-networks".
Have a lovely day!
Radu0
