Unanswered question
If I have unused data one month can I rollover but get a plan without data the next month and still use that data from the previous month?
No you need to have a plan with data to be able to use your roll over. If you remoce the data in your plan you'll lose your roll over data.
according to their website, sounds like you can change other parts of your plan and keep your rollover. But agreed, you probably need to always have data in your plan
https://fizz.ca/en/faq/how-do-i-know-if-i-have-rollover
if you gift you data and make a plan with out data. Yes you can do it but your not gonna be able to receive date from other.
Unfortunately, you'll need to have a minimum data plan.
As someone said in other post (ID is V.C ?) , your data upgrade (250m) can still rollover to next month if you can't used all.
