Whenever I click the “Resend me the notifications” button, I get an error message immediately with no other details. Anybody else have this issue as well?
I've set up a few phones and sometimes i got the notifications and sometimes I did not. I think the trick to be able to get the notifications is to restart the phone. If you get the ERROR, it's because FIzz never sent the notification. Once they send it, then the resend works.
In the phone I just set up now, I did not get the notification when i put the SIM in. I just got the first text message from Fizz that my activation was complete. So naturally I went to do the Resend, and had the ERROR. I figured I would restart the phone to see if I get the notification and I did. At this point if I try to click resend it works.
So folks try to restart the phone after you get the first text that your activation is complete and you may get the notification for the network parameters.
Otherwise like others said you can do it manually.
Same here. Fizz site gave me the same error...
Chizz :))
@James M.
I wonder if it's related to the fact that I'm using an iPhone though.
I can't send them either. But you get get the APN here an manually add it.
That worked last week when my friend used it. You can just add it manually though. It's not difficult.
I have tried several times over the last month and although I haven't received an error I've also never received the network parameters. I just set it up manually. I don't think there's any real difference either way.
I use android, and nothing happens when I click on "resend network parameters". No error, but no texts either. I think that part of their site is just broken, nothing to do with android or iphone.
I tried again just for fun and I still didn't get an error but also still didn't get any texts.
I am also facing the same issue :(
Data was working initially after inserting the SIM. I was not getting incoming messages. Also, I didn't get the APN settings message. I have configured the network setting manually. Now, data is also not working!!! very strange...
You can do it manually.
I had the same problem and I did it manually and it fixed the problem. Now my intrnet data works.
Does anybody knows what to do if the sms with image or video eoesn't work?
I can only send and receive text messages, but not images.
Thanks.. after doing configuration manually everything started to work after sometime, I forgot to mention here.
Well, if the 'resend parameters' doesn't work, why don't you remove the button, in order to avoid confusion?
Otherwise, make the interface user friendly, so that people actually see the rest of the page, and don't go elsewhere to clarify on the issue
Actually even better, remove all the content, but this:
"Steps to follow for configuring the APN can vary from one phone to another. Here's an example:
Settings → Connections → Mobile networks → Access Point Names → APN
Fizz APN settings are:
APN: mobile.bm
MMSC: http://mms.mobile.bm
MMS proxy: mmsproxy.mobile.bm
MMS port: 80
APN type: default,mms,supl"
from https://fizz.ca/en/faq/what-are-fizz-network-settings-apn
i am texting and the message will not send its always telling me errors
Francesco was made best respondent
Francesco answered
jcarpini answered
Efim Muratov answered
kamurb answered
sahar answered
kamurb answered
kamurb answered
Jonathan answered
ALLISON answered
ReneD answered
Jonathan answered
Ken answered
ALLISON answered
ReneD answered
James posted a new question
