Anyone else not able to use the data gifts they receive? All my gifts come in to the data meter saying they are used. After a while, some will switch over for me to use. But two remain stuck in the used position. It's been almost a week now.
Must be a bug , I suggest you contact fizz on Facebook messenger with this link : https://m.me/fizzca
It will be used earlier than your purchased data. There is a bug on web interface but you can use it, no worry. I sent my perk data to others and used all in one week.
Agreed. There's still bugs here and there on the site. Guess they are concentrating on the network first.
Good to know. Thanks Yun.
Is it working now?
My data always worked. I'll see what happens after I use all my gifted data. Will it start using the data that came in as used, or will it use my plan data. According to Yun, the meter is not working and it should start using the gifted data. I will update when I find out.
