my plan has not been fully activated. what should i do?
I activated my plan but it seems it's not been fully activated since I have no option in the mange page of my plan except "Add User". what's the problem and what should I do?
Did you find this useful ?
No (0)
Yes (0)
If you are porting your number over, it might take a couple days to get it all working. You’ll get an email with the contract once it’s done.
Ken
Ken
Ken
Level
5000 / 5000
Network problems today likely causing all sorts of issues. If it doesn't get fixed soon, you may want to contact them directly
MoYe
MoYe
MoYe
Level
3
3973 / 5000
you have to wait till the netwok is fixed
Mohammad
Mohammad
Mohammad
Level
3
2349 / 5000
Network is up. n running
