At level 1, I got a 250MB data upgrade with a 2GB plan, would this have been different on, say, a 4GB plan?
Hi, the 250mb bonus is the same for all. I got the 8gb plan and got 250mb as well.
It's important to note that once the bonus is applied to your account you can't remove it and you only have 1 'slot' available before level 3.
At level 2, you will receive a 500mb bonus but won't be able to use it since you've already used your only available slot for the 250mb bonus.
It would be good to know the answer from Fizz however all the documents I found on the site say that there is a "secret" algorithm that regulates the points :)
@Sean H. That is very useful information, particularly because I'm close to level 2. I think most who joined during beta (vs launch) got a 100mb data upgrade, not 250 though.
