can i keep my current # from another provider and transfer it toa fizz plan ?
as the title says I want to transfer my current provider to a fizz provider, but I can't seem to find an answer to whether this is possible or not, so is it possible to transfer my current # with a different provider to fizz if I don't already have a plan
Nessren
Nessren
Nessren
Level
Did you find this useful ?
No (0)
Yes (0)
Mathieu
Mathieu
Mathieu
Level
1
399 / 750
Yes you can transfert your current phone number
Nessren
Nessren
Nessren
Level
Please send the steps and a clear answer >>>
Yes Nessren you can!
If you need a reference code let me know! We will benefit from 25$ each! :)
Good luck and have a nice day! :)
kokoboko
kokoboko
kokoboko
Level
2
1289 / 2000
yes. only if is a cell phone number. GL and join Fizz family !
jeff3000
jeff3000
jeff3000
Level
2
1783 / 2000
Yes you can but keep your current serice up the transfert will automatiquely end your old subscription. Juste order/buy a Fizz sim and follow the instruction they will ask you what number you whant to transfert. Have a nice day:)
Yes you can, we did that also. We were with Videoton, we transferred the number, waited for the account with Fizz to be activated and then we called Videotron to cancel everything with them. It is supposed to be cancelled automatically but Videotron didn't do that. They saw that we transferred our number but cancelled our account following our call.
Leifuer
Leifuer
Leifuer
Level
5000 / 5000
Definitely yes!
For me, I am using my previous provider's number
MTeasdale
MTeasdale
MTeasdale
Level
1
494 / 750
Yes you can. That step is done when activating a new sim card.
Dominic
Dominic
Dominic
Level
3
4690 / 5000
Yes, and it is easily doable (done when choosing your options and activating your sim card)
