No signal in my basement. What to do?
Hi friends,
For a while, based on my work schedule, I moved to my home basement with my office laptop. I have an issue. There is no signal with Fizz and I ve got a lot of calls on my landline from people that couldn't call my cellphone.
What can I do ? At FM i had Wifi calling and able to use the cell in the basement. How can I activate Wifi calling with Fizz?
Use Network selection / Manual selection not automat / choose FizzExt will be roaming with Rogers . Try 2G for better walls penetration.
Did you find this useful ?
No (0)
Yes (0)
Manny
Manny
Manny
Level
2
976 / 2000
You can buy a cell phone signal booster for that! Look them up, good luck
That's right. No Wi-Fi calling yet with Fizz.
You can try 3G network or Fizz EXT (for occasional use only) as you may get a better signal, but forget about 2G. There's no provider in Canada using 2G network.
p.s. Cristi, that was really fast. You closed the question right after I posted.
So your response is really confusing. You picked my answer first, then Kokoboko's reply.
To me, using Fizz EXT in your basement is not a long term solution.
And you were able to connect to 2G network? That would be a really good one.
If you ask questions in the community, you should give valid and correct feedback.
This also means that the answer you select should reflect a correct answer for others having the same situation as well.
I think you should review the community guidelines here:
https://fizz.ca/en/community-user-guidelines
