SIM card fell in water ... now not working but I also broke my phone. Not sure which one is the issu
Kemal S.
Kemal S. Posts: 14 ✭✭
Please help what I should do
    Mike Posts: 20,751 ✭✭
    Hi Kemal
    Try the SIM in a different phone, the card is more difficult to broke if in contact with water
    You can always order a new SIM for 10$ +TX and swap it
    https://fizz.ca/en/faq/how-do-i-order-sim-card
    And this to swap it
    My plans > Manage > Change SIM card
    1- Click on this link: https://fizz.ca/en/faq/found-mobile
    Fizzy Posts: 10,924 ✭✭
    Hi Kemal
    Try wiping the SIM card contacts with some rubbing alcohol.
    As suggested to help narrow down the problem, you can test your SIM card on another phone.
    And test with another SIM card on your repaired phone.
    If you need to replace the Fizz SIM card, you can pick one up at a participating Couche-Tard: https://fizz.ca/en/sim-card#stores
  • Mélissa L. 86360
    Mélissa L. 86360 Posts: 74 ✭✭
    Oh boy! Not a good day for you... I would try to put the SIM card into another phone (after drying it of course! :P ). You will quickly see if the SIM card works.
