GB to give ! :)
![Fernanda T.](https://us.v-cdn.net/6032561/uploads/avatars_fizz_final/n15739318.png)
Fernanda T.
Posts: 2 ✭✭
I've got 4 perks 1GB to give !
![:) :)](https://forum.fizz.ca/resources/emoji/smile.png)
20
Well I'm open for that :P I need to stream on my data these days!7
Kudos well deserved!!! People like you make this community awesome :-)7
That is really generous Fernanda!
Thanks for helping the community6 -
Hi Fernanda
Sorry to tell you this
You can not gifs perks at the moment
Unfortunately Fizz had to disable the search contact option for now, likely to investigate this problem: https://community.fizz.ca/questions/2544662-fizz-members-targeted-text-message-phishing
We'll have to wait for Fizz to reactivate it.
Meanwhile you can still gift data from your plan to other Fizz members.
Go to My Plans → Click gift from the account → Start Gifting -> Gift to a new fried
Enter the phone number or email This will open the gifting tool, it is preferable to use the phone number
- Select the amount of data you wish to gift and click Next.
- Customize a message to the recipient and click Send.7 -
Thanks I'm ok for now but heres a kudo8
Mike is correct with a small note.
You can gift Perks only to Fizz members on your contact list.
However the add contact function has been disabled for about a month now.
So for now, you cannot gift your Perks to strangers.
You can use the Perk yourself or gift it to someone already on your contact list or wait for Fizz to bring back the add contact function or allow Perks to be gifted in the same way as mobile data.6 -
Always up here for more. Id just get my oculus and thats a huge consumer of data haha!
NK96N
Thank you and have a great day!6 -
Alexandre, please stop posting your referral code.
You may edit the post to remove it.
You may send a private message (PM) with your referral code. However you may notice that Fernanda is trying to gift perks (not mobile data) which cannot be donated to you right now.
Referral codes are permitted only here: https://community.fizz.ca/questions/2198337-place-referral-codes7 -
@ Alexandre,
You dont have the right to post your referral code.
I signal it.3 -
Nice gesture Fernanda!1
