slow speed when wired?
I have a 120 mbps plan on my 5gz good speed on my 2.4 ok speed but when I'm wired I only get 41 Mbps max as download and 20.30 in upload.....why?
  • Yassine A. #39610
    If turning off doesnt solve the problème. Make sure the wired device device is not old. Some older devices are not able to support the actual speed. Try wiring another device and see what the result is.
    MichelP Posts: 8,733 ✭✭
    Annie,
    Maybe, doing a factory reset of your modem can help to get a better speed.
