Correct APN settings for Note 20 Ultra 5G android 11 ui 3.0
ANDREI T.
ANDREI T. Posts: 3 ✭✭
I bought a new Nore 20 Ultra 5G. Insert the Fizz card all ok. Update phone at android 11 ui 3.0, received 2 messages with "correct settings " ,installed but from then no more tethering on my phone. I tried to modified after the old phone but the apn settings are a little different.No much success. Anybody encountered the same issue?
