Outgoing calls were not working until I received a call.
I was unable to make outgoing calls. I tried many numbers (VOIP, mobile and lan lines) and it would just not ring.
Then I had a friend call me, and it worked. Then I could make calls after that. What's the deal? What if I need to make a call at some point and can't ask someone to call me to "re-enable" my phone line?
It's all nice and dandy to not have a phone number for FIZZ, but when there are bugs in their systems like that, it would be nice to be able to report it.
Hi Yankee
Try restarting your phone.
You can also try your SIM card on another phone to rule out any issues with your current phone.
If the problem continues, you can contact customer support by chat:
3- Open a Fizz help page like this one: https://fizz.ca/en/faq/how-do-i-make-sure-my-mobile-servi...
Did you find this useful ?
No (0)
Yes (0)
Yankee
I find that their page "Service Status" is useless
If you will have a similar probable again, you must try to reboot the phone, this will force a new registration
Did you checked the signal level?
If this problem will be present again, please contact the support to investigate
1- Click on this link: https://fizz.ca/en/faq/how-do-i-make-sure-my-mobile-servi...
cristi
cristi
cristi
Level
2
1852 / 2000
Sending a sms helps... usually when their is a congestion.... like if there is a high density population area and just a few cells and the traffic voice/data is high,
StefanM
StefanM
StefanM
Level
5000 / 5000
Must have been a resetting issue. I am glad it works now :)
Hi Yankee,
You should try to restart your phone
Than, try your SIM card in an other phone.
If nothing works, contact FIZZ support.
Have a nice day.
