it happens even when i call local and i tried calling the number directly same result & when try to disable call forwarding it tells me my plan dosent let me make this call
You can also try dialing one of these codes to disable Call Forwarding:
- #21# to deactivate universal call forwarding
- #67# to deactivate call forwarding when busy
- #61#...
So, I have a fizz number that is being forward to a Telus number. Currently, the fizz number plan has “voicemail”. What will happen if I cancel “voicemail” from my plan? Will...
Hi SteveMtl
“Conditional call forwarding” is used to forward your calls to a different phone number, if and only if you don’t pick up the phone when you get a call.
If...
Did you change the option for the call forward?
https://fizz.ca/en/faq/how-do-i-set-up-call-forwarding
Do you have a voicemail option?
Check in your transaction history...
Hi i read a lot of the post in the question section who say we can block number and it's will block them on the voicemail too who is completely false because android will report...
Hi Nicolas
You are correct. If you block a caller, the call will go directly to your voicemail. Spam callers can be annoying.
Here are some options you can do to prevent...
