I already tried everything it says I got no service so I bought another sim card from fizz and I wonder if I could continue my plan with another sim card
Hi Meekael,
I can see that you've already contacted us regarding this situation and a colleague of mine has given you a handful of helpful tips to try out and see if you can use the service under the new SIM card added under your mobile plan.
Please try them out and let us know if they helped.
Here you can find more information about how you can do that: https://fizz.ca/en/contact-us
Have a good one!
Andrei
Ho Meekael
Yes you can swap the card, you plan will be on your new SIM
My plans > Manage > Change SIM card
YEs it will work with another sim card from fizz :)
I won't have to pay again? because I already paid 4 days ago for a my other sim but it doesnt work
Yes, you can always swap your simcard. Your plan will remain unaffected.
Hope this works for you. Yes you can change SIM card.
