TAP splitter connection for internet
Sylvain T. 82381
Sylvain T. 82381 Posts: 15 ✭✭
Hi, a technician attached my cable to a TAP splitter since the signal was too strong. Moved the modem elsewhere but forget where to connect the main cable and the coaxial cable to the modem. For each can you tell me where it goes for the IN, OUT and TAP input. Thks
