Can All the Plans call the US?
Hi Meyer
Only if you buy an addon, or you have money in your Fizz’s wallet you can call in US with the Quebec or Canada coverage when under your coverage area
However, if you have a Canada/US coverage plan with unlimited calls, then your call to the US are included if you are in Canada or US
If you are in the Fizz Ext remember this rule
We reserve the right to interrupt or block access to our network of partner providers Fizz EXT if you use your mobile service primarily on their networks for 3 consecutive payment cycles.
Source: https://fizz.ca/en/faq/partner-networks
Hi Meyer,
In order to be able to call to the us you either need to add Canada/US Coverage or buy an add-on
No, basic voice plan is Quebec only.
Hi Meyer,
You should think of FIZZ as a pre-paid provider. To call US you have 2 options:
1) Have a plan that contemplates the US. (I personally do pay for CANADA + USA and my phone works fine across the boarder. It also enables me to call US phone numbers from within Canada with no issues)
2) Buy an add-on or travel package if you are planning to go to US. These work fine.
There's even a 3rd option if you want to call US from within Canada which is to add funds to your wallet here in Fizz. I'd suggest this method only if it's a 1-time call. For more habitual calls do switch your plan to cover Canada + USA.
I hope this helps.
