I am sure I have voicemail on my plan, but whenever I try to activate it, it says my "number is not quite right". How do I fix this?
Hi Qiuguo
Are you calling the voicemail from your Fizz phone?
If you forgot the PIN, you can reset it from your Fizz account: (Under: My Plans > Manage My Plan > Advanced Settings > PIN to Access Your Voicemail).
You can also check if your voicemail is accepting messages by calling your Fizz number from another phone.
If you want to contact Fizz support, you can Live chat with support:
3- Open a help link page from Fizz Solution Hub: https://fizz.ca/en/faq/how-do-i-set-up-my-voicemail
That’s weird. Try to manually access your voicemail via : 1-514-647-0999 (or press one).
More information here : https://fizz.ca/en/faq/how-can-I-access-and-use-my-voicemail
Try to reset your PIN from your account. It should work then.
Qiuguo,
Please, reset the PIN in your account.
Log to your Fizz account.
Click on: My plan - Manage my plan - Advanced settings - PIN to access to your voicemail
Please, choose a PIN not too easy to remind:
For example, 1,2,3,4 wont work.
Hello Qiuguo,
Thank you so much for your message. Checking your account, I notice that the voicemail feature is not included in your mobile plan. I notice you were able to also reach us in the meantime and we informed that if you would like, you can indeed change your plan to include this, however regular fees will apply afterward for your plan, as you can also see on our page: https://fizz.ca/en/faq/important-information-mobile-membe...
Thank you so much for your understanding.
Have a lovely day!
-Ioana
