Under travel the website only mentions Data, I don't find a single word on texts or phone calls.
Is it possible to still receive calls when travelling to Europe by purchasing some Add-On?
Hi Andy
No you cannot have addon for the calls outside Canada and US
However, as suggested by Fizz you can use VoIP app ( I like fongo), and therefore buy data addons or use wifi
In the meantime, probably you will be better off to buy a local SIM card
This is the Fizz’s text
Important : You will not be able to make calls while roaming outside your Canada or the United States.
Roaming calls (incoming or outgoing) will be available at a later time. We will update this FAQ when we have a firm date.
In the meantime, you will be able to use data, and send/receive texts when you travel outside your coverage zone. To make and receive calls, you can use messaging apps such as WhatsApp or Messenger.
Source: https://fizz.ca/en/faq/im-travelling-outside-my-coverage-...
Unfortunately only texts and data for now :/
