I changed Chanel from default but still bugs
Hi Daniele
Sorry you are having internet issues.
Please unplug the Fizz modem from the wall outlet for 2 minutes. Then restart it and try a speedtest.
Try to connect to your modem with ethernet cable or with the Fizz app, this will give you an accurate measure for the speed test.
If the problem continues, you can try factory reset of the modem by pressing and holding down the small button behind the modem for 10+ seconds with a sharp object like paper clip. If you doing this you need to reconfigure the modem.
Keep in mind that the maximum speed of your plan is the total bandwidth speed shared among all users in your home.
Does the speed issue happen with wifi only or also with ethernet connection?
You already try but try an other channel
If the problem is happening with wifi only, you may benefit from disabling auto channel selection in your modem admin settings, and selecting a specific channel. You can find the channel which is least congested by using a smart phone and downloading a WiFi analyzer app, which will show you the channel usages of nearby devices.
To change the channels:
1- Connect to your Wi-Fi network.
2- Open the browser on any device, and enter the address 192.168.0.1
3- Log in using these credentials:
Well, not much to add to Mike’s answer.
Yesterday I had some speed problems too. I just turned the modem off/on and it started to work again
Yes, turn the modem off and on again !
