Hi! In order to lock my SIM in my cellphone, I need the 4 digits PIN that is provided by you. Since I only have 3 tries before my phone gets locked, I'd rather ask you for the answer.
Hi Jonathan
This is the procedure https://fizz.ca/en/faq/how-do-i-personalize-my-pin
How to personalize the PIN on most phones:
Go to the Settings menu → Choose Security → Choose Modify your PIN
However, this I do not see how can prevent the phishing, this will lock your SIM
This will not prevent nothing more
These are the informations for the PUK
https://fizz.ca/en/faq/how-do-i-use-puk-code-to-unblock-m...
Hello Jonathan,
Most phones have a built-in shortcut for changing your pin. So, for example, to change the default pin to 5555 you need just one command to type:
**04*1234*5555*5555#
where: 04-command code
1234 old pin
5555 new pin (must be typed twice)
Of course, you also need to check the card that accompanies your new SIM card to determine your old pin!
