While roaming in Nova Scotia with Canada-wide coverage on my plan, eventhough the coverage map show support for almost all the province, I have terrible coverage! My mobule connection is almost always at 0 bars. When i make a call, it wont go through until at least one bar shows up. I'm not in a super remote area, but it is rural and above ground so there are no obstructions. Forger about mobile internet speeds and I can only imagine how many calls I've missed. I always had full covererage with my previous providers when i was roaming in Nova Scotia with Virgin Mobile and Telus Mobility.
@Geoffrey
Sorry it seems that they do not have an agreement with that providers.
You must contact the support to see with them your options
Hi Geoffrey
Did you try to select an other Fizz Ext?
Fizz has agreements with providers which can have limited coverage in your zone.
Here are two examples:
Android: Settings → Connections → Mobile networks → Network operators → Search networks
iPhone: Settings → Operators → Search
You can contact Fizz support by chat
2- Click on this link: https://fizz.ca/en/faq/subscription-area-and-coverage-area
Which one?
Geoffrey
You should try randomly since the name is replace by Fizz Ext, but they are different providers
The first 2 "Fizz EXT" options connect but are 0 bars occassionally going to 1 bar. The 3rd one gives me 4 full bars, but actually isnt a connection and says i am not connected to any network, doesnt allow calls or data, and the 4th one doesnt connect.
Maybe is the covid-19 that affected your connection...
Hi, Geoffrey
Please, contact the Fizz customer service by chat and inform them that the roaming service in Nova Scotia is not really good with others providers.
If they can suggest something to get a better service.
