Signal is full but turn into emergency call only
Hiu
Hiu Posts: 6 ✭✭
I work in the hospital at Ottawa. After entering the building all connections are lost. With full bar of signal showing on phone but only able to do emergency calls. Are anyone expecting these problems?
    sman Posts: 4,294 ✭✭
    Probably you are in Fizz Ext
  • PierDuc
    PierDuc Posts: 1,564 ✭✭
    Hi Hiu,
    You should check with the hospital, it is probably them who are blocking access.
  • Hiu
    Hiu Posts: 6 ✭✭
    Thanks guys. I'm talking to the fizz support group right now hopefully they can give me an answer since they responded that I should be able to use it in the building
    MichelP Posts: 8,733 ✭✭
    Hiu,
    Thank you for sharing this information with the community..
  • LemonHead
    LemonHead Posts: 355 ✭✭
    Good question. I hope they got it fixed for you!
