Hello, are there any mobile users in the Ottawa subscription area but outside the urban core and do you experience good service/reception with good and consistent mobile data speeds?
Hi Clive
You can check the Fizz coverage map here: https://fizz.ca/en/coverage
And you can see all the cell tower locations on this map: https://www.ertyu.org/steven_nikkel/cancellsites.html
Note that your phone services will only work in the coverage area you have chosen for your plan. Otherwise, you can purchase travel add-ons if you need services elsewhere.
You must enable roaming to use mobile data outside of the subscription area. And if it doesn't connect automatically, you can try restarting your phone.
See the converge map..
More info on my posting:
