Hi everybody,
I noticed that we can accumulate points and then get rewards with them but i don't understand how it works.
Can somebody tell me what are the different ways to accumulate rewards points?
Thanks for your answer
Check the table
Hi Francis,
As you probably understood with Mike's table, you basically have to be active on this forum.
The more often you are here to give kudos, ask and answer questions, the more points you will earn.
Welcome to the forum!
As long as your active on the forum, you will get 5 points for each answer and 5 points per kudo which means you want to get as much answer as possible.
Participate on the community hub, try to get best answer questions gives 50 pts, give data, referring new Fizz customers, give every day 20 kudos, receiving kugo give you 5 pts.
Paying your monthly plan.
Hi all, is giving Kudo clicking the heart on these posts ?
