I saw in the community posts that in April 2019, there were issues with Huawei cellphones. I'd like to know if the issues are resolved & if LTE works on Huawei p20 pro. please don't copy the text that indicates what hspa & max I need for it to be compatible because I don't know how to search that on my phone. thank you
Hi Alexia
It is almost a year that I do not see any message regarding huawei problems.
On that period Fizz had some issue.
Check the model
EML-L09C, EML-L29C (Global); EML-AL00, EML-TL00 (China, Hong Kong)
For example L29c is compatible looking to this site
https://www.frequencycheck.com/models/AadVB/huawei-p20-gl...
To see if it is compatible with Fizz network
EDITED since my phone is in moderation
From the information from this site, your phone is compatible
https://phonedb.net/index.php?m=device&id=13364&c...
hi mike, my phone model is CLT-L04. I feel like you didn't answer my question. are you trying to say that those past problems are resolved, my phone is compatible and I will have LTE on my huawei p20 pro?
My usa version mate 9 works on lte just fine. My china version still 4g only. No lte.
Yes I guess china version Huawei mate 9 lack bands.
Don't know p20. Sorry.
I bought my p20 pro from rogers. idk if that helps.
@ mike , I just noticed that you edited your message. if you say its compatible by what it says on the site, that's great! thank you for doing research! lets hope it actually works haha
