My data on my phone wont work I already tried everything i found on the website can someone help me? I have an Android
My data wont work, the LTE symbol does not appear. I have tried everything in the forum discussions
Stacy
Stacy
Stacy
Level
Whizz
Whizz
Whizz
Level
5000 / 5000
Team
Hello Stacy,
We're so sorry to hear about this situation. I checked your account and your line is active and in good standing, there's also plenty of remaining data left. In this case, if you're currently in a location within your coverage area, I suggest first to restart your phone and once it's back on, make sure your Wifi is turned off and only mobile data is on.
I also recommend disabling automatic network search, then manually connecting to Fizz EXT then back to Fizz and test your data on both networks. Depending on your device, you will be able to do this from:
Android: Settings → Connections → Mobile networks → Network operators → Search networks → Fizz EXT then Fizz
iPhone: Settings → Carrier → Fizz EXT then Fizz
Kindly also test the sim in another phone as well, to see if the situation arises in both devices. If you have an Android, it will also be useful to follow the steps Mike recommended. You will find more useful information on our page: https://fizz.ca/en/faq/how-do-i-use-my-phone-to-access-th...
Should you still encounter an issue after these steps, please reach out to us so we can make the necessary verifications and help: https://fizz.ca/en/contact-us
Thank you so much for your understanding.
Have a wonderful day!
-Ioana
Did you find this useful ?
No (0)
Yes (0)
Hi Stacy
Did you check if your phone is compatible?
Do you have data in your plan?
Can you try this
You can try to configure the APN manually. Here the full configuration
For Android phones
For internet
APN: mobile.bm
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 500
Authentification type: Not set
APN type: default
APN protocol: IPv4
APN roaming protocol: IPv4
Enable/disable APN: checked
Bearer: Unspecified
Mobile virtual network operator type: GID
Mobile virtual network operator value: 55
For the MMS
APN: mobile.bm
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mms.mobile.bm
MMS proxy: mmsproxy.mobile.bm
MMS port: 80
MCC: 302
MNC: 500
APN type: mms
APN protocol: IPv4
Bearer: LTE
You can contact customer support by chat, from 8 AM to 9 PM every day:
3- Click on this link: https://fizz.ca/en/faq/i-cant-send-or-receive-multimedia-...
