I am temporarily move to New Brunswick so my mobile data , calls, texts is available?
Dhanrajsinh
Posts: 1 ✭✭
I am going to New Brunswick (grand falls) for a week is my plan is working there?
26
If you have a canada coverage yes
Otherwise you need to buy addons, or you can change your plan
If you change your plan here something that you need to know
You need to change at least 48 hours before the next billing cycle
You need to wait the next billing cycle for the plan modification13
