Lte mobile speed near the Canada US Border ?
Pierre-Olivier C. #36244
Posts: 3 ✭✭
in My Mobile
Hi new member here, so nice the see a community of people helping each other ! I have a question, do any of you know if the data speed (LTE) fast near the US Canada border ? Thanks a lot
36
Hi Pierre-Olivier
There should be no issues, but it will depend on where you are exactly.
You can check the Fizz coverage map here: https://fizz.ca/en/coverage
And you can see all the cell tower locations on this map here: https://www.ertyu.org/steven_nikkel/cancellsites.html
Note that your phone services will only work in the coverage area you have chosen for your plan. Otherwise, you can purchase options for additional services.
You must enable roaming to use mobile data outside of the subscription area. And if it doesn't connect automatically, you can try restarting your phone.11 -
You can check the Fizz coverage map here: https://fizz.ca/en/coverage11
Depends. If it's vermont Rea, it's only 3m11
