Internet (60 Mbps download) showing as being at half speed. Normal?
Other than this PC, no other devices should be connected to my Internet at present, yet the download speed is half of what I'm paying for. I disconnect the modem for a few minutes to reboot it, but the speeds are only a bit better (see attached).
Over the past month my wife has complained (numerous times) that the Internet isn't stable enough for her teleconferences. She's often the only one using our Internet, hence even at my currently "low speeds" should be enough for her work, or so I would have thought, no?
I'm changing my plan from the 60/10 to 120/20 but I'm not sure if their is something else that could explain the problem. Thoughts?
Simon
Simon
Simon
Level
1
457 / 750
Hi Simon
Try to connected the computer with the ethernet cable or with the Fizz's app, this will give you the real speed
Have you tried restarting your modem?
You may benefit from disabling auto channel selection in your modem admin settings, and selecting a specific channel. You can find which channel is least congested by using a smart phone and downloading a WiFi analyzer app, which will show you the channels of nearby devices.
1- Connect to your Wi-Fi network.
2- Open the browser on any device, and enter the address 192.168.0.1
3- Log in using these credentials:
Username: cusadmin
Password: (Enter your password, the one you chose when you initially configured your network)
4- In the green bar, select Wireless.
5- Then select: General settings → 5 GHz and/or 2.4 GHz → Wireless channel
6- Select a different channel.
Choose a channel that’s far from the one your modem currently uses, and test it for a few days to see whether things improve or not. Ex. Go from channel 6 to 11. Or, from channel 6 to 1.
Your Fizz Wi-Fi modem uses by default the to frequency band steering technology. When this function is disabled, the Wi-Fi modem will display two (2) frequency bands, 2.4 GHz and 5 GHz.
1. Log in at: 192.168.0.1 from the web browser of any device.
Username: cusadmin
3. Go to the next section to apply changes: Wireless → General Settings → 5GHz → Band Steering (Disable)
Si rien fonctionne contactez le support
You can contact customer support by chat, from 8 AM to 9 PM every day:
3- Click on this link: https://fizz.ca/en/faq/my-wi-fi-network-cutting-how-do-i-...
Did you find this useful ?
No (0)
Yes (0)
Simon
Simon
Simon
Level
1
457 / 750
Oops! I just realized that my speeds are OK when the PC is connected with the ethernet cable (it had disconnected).
I'll check my wife's PC in case it's a similar "problem". ;)
Minh
Minh
Minh
Level
1
185 / 750
if you still need help, you can ask fizz on facebook messenger, they always respond!
Minh
Minh
Minh
Level
1
185 / 750
seems like you already got the answer, but if u still need help you can contact fizz on facebook!
