Wifi Range extender with Fizz router ?
Hi Everyone,
I just subscribed with Fizz and thinking of having a wifi range extender to cover some weak signal place in my home.
I'm wondering if ASUS RP-AC1900 Dual Band Wi-Fi Range Extender is compatible with the router provided by Fizz ?
Or anyone have any suggestions for a wifi range extender ?
Thank you !
Thank you !
21
Hi Heng
If you do not have it yet, probably you are better off to take a router directly to associate with the Fizz Modem
If you have it, yes it is compatible, the WifI is a standard.
Asus make good routers, with more functionality offered by Fizz Modem
this is not bad Asus RT-AC68U, but you can take linksys, tplink, dlink or others
this is the guide
https://fizz.ca/en/faq/how-can-i-use-my-own-wi-fi-router-fizz6 -
Hi heng,
We use Linksys Velop. Works real fine.5 -
Thank you guys for all your answers, I will probably purchase the suggested brand extender.2
