can't place a call?
Jacqueline H.
Posts: 1 ✭✭
in My Mobile
hello, my plan has a whole Canada coverage, but when i try to call someone that lives next to me it says i cant call its a long distance number
18
Hi Jacqueline,
did you try to add 1 or +1 to your number
You can also try to reboot your phone
Do you have unlimited calls?
If this does not help, feel free to contact the support
2- Click on this link: https://fizz.ca/en/faq/I-cant-make-any-calls-on-my-phone-why
3- The green chat bubble should appear after a few seconds in the bottom right corner.7 -
Jacqueline,
Do you have a new phone number ?
You should not have to dial 1 if you are calling next door.
If you have a new number, is it the the right area code ?5
