Does anyone use a signal booster to overcome poor signal from Fizz Mobile and if yes does it significantly improve signal?
Hi Clive
You can find an inexpensive LTE/3g booster on Amazon or other sites and if it doesn't work, you can return it.
I also suggest to search online. There are many available.
Clive I’m using a router and YES it’s a significant change. I can have wifi in my backyard.
Here it’s how to use a router https://fizz.ca/en/faq/how-can-i-use-my-own-wi-fi-router-...
Clive no sorry I never used one. But I read in the forum that it could improve the signal...a little.
Clive,
Sorry, I don't have this problem.
I supposed to be helpful to get a booster for your line.
I hope you will get an answer of someone who have experienced it personnaly.
Hi Clive,
Sorry about your poor signal.
Sincerely hope someone can help you find a solution.
Clive a fizz user said few months ago...For me since a few years I use this one from Amazon: https://www.amazon.ca/-/fr/gp/product/B01F4RPA4O/ref=ppx_...
It is working well with FIZZ for me.
Hello Clive,
We're sorry to hear that you're currently encountering a situation with your signal. I checked your account and saw that your mobile plan is active and in good standing. In order to be able to help remedy this, we will need as much information as possible, whether it's only a data situation for example or you simply have weak network in certain areas. I kindly invite you in this case to reach out to us so we can make the necessary verifications and help: https://fizz.ca/en/contact-us
I can also share this page with you, that you may find helpful: https://fizz.ca/en/faq/what-can-i-do-if-mobile-network-co...
Thank you so much and I wish you a lovely day,
-Ioana
