Can I use my sim card in a portable LTE device?
Francesco N.
Posts: 2 ✭✭
in My Mobile
I am wondering if I can use my sim card in a portable LTE router and add data to that sim?
15
Hi Francesco,
it seems a similar question https://community.fizz.ca/questions/2495059-can-use-data-mobile-hot-spot
But yes you can use the SIM on the LTE router, the router must be compatible.
All the SIM have a number associated with them, but you can have a SIM with 0 minutes and add data, the biggest plan is with 20Gb11 -
Francesco, I'll second Mike's suggestion. You can use the LTE router like a mobile hotspot or a source of data with a Fizz SIM card.8
You can though if you want to share your mobile data with other devices I suggest an easier option may be to use the Hotspot feature on your smartphone, either the wireless WIFI or USB option.6
does it work, i'm curious2
Francesco,
Yes you can and choose a plan with a maximum of 20Go of data.3
