How to disable bridge mode to have wifi directly on Fizz modem?
George S. #20091
George S. #20091 Posts: 639 ✭✭
How to disable bridge mode to have wifi turned on directly on my Fizz modem?
    MichelP Posts: 8,733 ✭✭
    George,
    Please,
    Do a reset of your modem.
    With a needle, presse in 35,40 seconds the reset button located in the center back of the modem, released it after.
    Wait 3,4 minutes until you see the modem lights coming back.
    If your computer is connected to the modem, you'll see on the screen: Easy connect.
    Types twice the factory password indicated back of the proble.
    Your internet connexion is supposed to be 100% fonctionnal.
    Reconnect all of your devices to your wi-fi network with the same password.
