Does Fizz data ever works in Fabreville?
BOT001
BOT001 Posts: 6 ✭✭
This is unacceptable. I was hoping to be able to browse the net on my phone but it's worst than dialup. Tried to switch in 3G, 2G, LTE none of them works .
  • Clive_ref_code_73TF9
    The short answer to your question is your mobile data connection will be slow if you are far away from a cellphone tower and if lots of other cellphones access that same tower.
    You can try manually selecting Fizz under network settings and/or forcing your device to run on 3G (different phones have different procedures but here is a link for most. Use it only if you are somewhat technical....https://www.dtechy.com/change-2g-3g-4g-network-android/).
    I this does not work to improve your mobile data speeds, contact Fizz customer service for assistance.
