What pin should i use to read my vice message ?
NGUESSIE
Posts: 2 ✭✭
15
Hi Nguessie
If you don't remember your voicemail pin, you can reset it on your account.
(Under: My plans > Manage my plan > Advanced parameters > PIN to access my voicemail)
IMPORTANT: Unsafe sequences will be refused (for example : 1234, 8888, etc.).8 -
NGUESSIE,
part 3 of https://fizz.ca/en/faq/how-do-i-set-up-my-voicemail
"Know that you can change your NIP directly via your voicemail, or online from your Fizz account (Under: My Plans > Manage My Plan > Advanced Settings > PIN to Access Your Voicemail)."
or this one part 3 https://fizz.ca/en/faq/how-can-I-access-and-use-my-voicemail
"To reset or change your PIN"
Have a good day
GBY6
