On Ontario plan , however shifting to Calgary soon . Can I still stay on fizz ?
Suvash you will not be able to use Fizz with your plan. And after 3 months with a canada plan it’s not possible either to stay with Fizz. But keep your Fizz number active if you want to transfer your number there.
https://fizz.ca/en/faq/im-travelling-outside-my-coverage-zone-what-are-my-roaming-options3 -
Hi Suvash
You will need to enable roaming on your phone. However you won't be able to use Fizz mobile outside of the subscription area (Quebec) for more than 3 months.
If you plan to stay in Calgary for 3 months or longer, you will need to make alternative arrangements for a mobile service provider.
Here is what Fizz writes:
"The majority of your usage (calls, texts and data) must be done on the Fizz network (Subscription area).
We reserve the right to interrupt or block access to our network of partner providers Fizz EXT if you use your mobile service primarily on their networks for 3 consecutive payment cycles."
source: https://fizz.ca/en/faq/partner-networks3
