Port Forwarding & uTorrent on MacOS
Hello Gilray, I am not sure the Fizz support forum is the best place to ask for torrenting advice. Your best bet is to google this information.10
Hi Gilray
Port forwarding with Fizz modem should work the same way regardless of your platform/OS.
Please go to http://192.168.0.1/login.htm
Enter user "cusadmin" and your wifi password.
Then proceed to the proper area as shown in the screenshot of this post:
https://community.fizz.ca/questions/2371882-modem-port-forward-wifi-signal-strength
Then add your rules and save the changes.8 -
Please disregard this question... I've just discovered that the configuration seems to be automatically done.8
Gilray, that's even better. Glad it is working for you!
If it can, programs will add the rule automatically for you.7 -
That should be automatic
Have a nice day!3 -
I'm glad you found your answer2
