Do I have to cancel my current home internet plan? Or will the technician do it?
Victoria A. #31205
Posts: 1 ✭✭
in Internet
Who cancels my current plan?
11
You should do it,. when everything is up and running contact the other provider to cancel, usually they will refund you calculating in prorated
Once your Home Internet plan is activated, don’t forget to contact your previous provider to cancel your Internet subscription with them, and avoid paying double.
source: https://fizz.ca/en/faq/how-do-i-subscribe-to-fizz-home-internet3 -
Victoria wait to see if everything is ok with your fizz internet and after call your last company to cancel your plan with them.3
The usual way is to call and let them know a cancel date. They will usually try to offer you a better price before you cancel, but they will likely be unable to beat Fizz!4
You can do it and send your modem by post Canadá. The address you will receive by e-mail1
Victoria,
Yes,
You have to cancel your actual internet provider
When your Fizz residential internet plan will be completely fonctionnal.1
